Hello to all!
Im thinking to change the carburettor from my sfera nsl 50. What can I install?
It has an PHVA 12 DD. Any suggestions?
Thank you!
Hello to all!
Thank you!
Hi,
if you do not plan to switch to a 70ccm big bore kit the PHVA 12 or the PHVA 14 is the best pick.
Otherwise it would be better to switch to PHVA 17,5.
Regards
Alex
Hello!
Thank you for the answer!
The 17,5 has auto-choke as well?
Hello,
normally the 17,5 carburetor does not include a choke. You have to use the one that is currently installed, otherwise you have to buy this separately (it has the same mounting holes as the PHVA 12 and 14).
Regards
Alex
